Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212вопросов Показать все
Logic Board Faulty or Damaged?
Hello There... I was wondering if someone can give some clue what is happening in this situation..:
problem: iMac won't turn on...
tests:
1. Removed lcd/glass panel successfully, I notice that NONE diagnostic led was on... so...
I went..:
2. I checked de AC cable, and it gave me the 120V AC from the outlet so we are good...
3. checked inside AC input in the Mac, and also gave me the 120V AC... (good)
4. I plugged in the PSU, and tested some pins with the ground pin... and 3 pins gave me 12V DC. (so I think the PSU is fine)
What else can I try????
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
The PSU may receive power but is not sending further to the board, before going after a logic board damage i would try with a new power supply. Most of the cases when no diagnostic led is on the board doesn't receive power due to a faulty power supply.
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
@kaykay another one hits 500
из
even though the PSU pinout gave me 12V DC on 3 pins?... I will try another psu..
из
Always keeping an eye out for me @mayer. Thank you :)
из
Hello there, after all.. I installed a new PSU, the imac start working again... but.. after several hours the iMac was on.. it turned off... so I checked again inside, and I have no leds on... (again)... I have no clue what is happening...
из
@makibuki //have u found problem. i have the same issue
из
Добавьте свой ответ
jbermudez27 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 254
