The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
58вопросов Показать все
Unable to disable the ultra power saving Mode
Hi,
I have the same issue. cannot exit Ultra Power Saving Mode — Tried the Ultra Power Saving Mode on a Samsung A5 6 16GB phone, no options to turn the %#*@ feature off — insidious — Have tried reboot in Safe Mode — When i drage the screen down there is no quick launch – There is only setting icon
In Settings there is — only Wi-Fi / Bluetooth / Airplane / Mobile Networks / Location / Sounds / Brightness are available —
There is no Personalisation option no battery option nothing.
Infact initially it was showing the the grey screen with 6 icons. but now it shows Home screen and Contact Apps other option
There is no Google App when i click on apps, Please help…
Это хороший вопрос?
Оценка 5
4 Комментариев:
Hi ,
i have the sameproblem < what should i do , plz?
из
Hi ..any resolution for the mentioned issue... ? Pls reply...
i am also facing the same issue since last two days... somebody pls help....
из
Even I have the same problem, please let me know how to overcome this issue.
из
No my phone can't go one I can't put my
из
Добавить комментарий
2 Ответов
Did you try to restart the phone?
If you did and if it didn't work you can try to reboot your phone in recovery mode :
-Shutdown your phone
-Start you're phone by pressing in the same time the home, volume up and power buttons.
Using volumes and power buttons you should be able to find how to wipe cache and dalvik cache. if it doesn't work the only way I see is to do a factory rese (!! A FACTORY RESET MAY REMOVE ALL THE DATA!!)
If you finaly found the solution please tell us !
Pardon my English
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
cant reset the phone since have no option for it
из
it worked for me-tecno phone
из
It's Simple I Had The Same Problem I Tried To Find Something Nothing Then I Just Remember I Can Reboot My Phone From Google Find My Phone It Might Work For U If U Have An Google Account In the Phone If It Not Just Add One And Tara Your Phone Is Rebooting If I Help You Follow On Instagram:
spicy.gabbagerollz
Оценка 0
1 Комментарий:
It didn't work for me
из
Добавьте свой ответ
Afsana Khan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 5,111
