The Protocol Dronium Two is a remote-controlled (RC) toy drone with silver colored, X frame body and four black rotor blades. It comes with an high definition (HD) camera and rechargeable battery.
Вопросов 4 Показать все
Prop Spins Intermittently while other props spin perfectly
Drone Issue:Props spins and after remotely stopping all props, the rear right prop will sometimes not spin unless you give it a push. I carefully removed the cover revealing gears and saw nothing unusual. I tested the shaft by starting props and the shaft in question does not spin on its own. If you turn it the shaft will spin again and MAY behave fine for two or three test but eventually it will require that you spin shaft manually to get the shaft spinning. Is this a loose wire problem? Thanks for any suggestions.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
alwazfresh , It sounds like a possible bent motor shaft sticking or weak/faulty motor issue. You will probably have to replace the motor. You may be able to find new or used part by doing a search or try a couple larger hobby stored that deal in drones. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
alwazfresh будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 184
