Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Battery connection pins broken, now what?
Hey guys, I was having some battery problems so I needed to keep removing the battery and putting it back to get the phone on. Last time i replaced the battery, some pins fell off the battery connection on the phone. How can I fix this in order to get a battery installed again?
Это хороший вопрос?
Оценка 0
2 Комментариев
Could you take a photo and post it here shared link if you prefer?
The connector probably needs to be replaced on the logic board.
из
Ok will post that once I'm home.
Will that require soldering?
из
Добавить комментарий
Ответов (3)
Выбранное решение
Yianni Pantaratos , As Ben stated the connector will probably need replaced. This part requires micro soldering and board level repair skills normally. Below are links to show how to disassemble the S6 and remove mother board, a link to replacement part and a link that shows what is involved in changing a battery connector to show what is involved(not your exact device). If not comfortable doing this repair have a good local cell/computer repair shop have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://d3nevzfk7ii3be.cloudfront.net/ig...
Samsung Galaxy S6 Motherboard Replacement
Galaxy S6 Battery Connector
https://www.youtube.com/watch?v=Dn_DS2c_...
Replace the battery cable connector on the motherboard of a Galaxy S6. This part requires microsoldering. Изображение
Продукт
$2.99
Был ли этот ответ полезен?
Оценка 3
The pins will have to be soldered back on the motherboard.
Оценка 2
Hi plz go to shop and repair
Оценка 0
Добавьте свой ответ
Yianni Pantaratos будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 6,583
