Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
16 gig ram upgrade causing problems
I put two 8GB DDR 3 1333 MH ram in my mac mini Mid 2011. It booted fine and the RAM showed up on the "About this mac" window indicating that it was OK, but after a short time it froze and the monitor had coloured lines running horizontal. Tried it with an 8 GB chip and a 4GB chip. It work okay for half an hour then went ape sh#t again. The monitor is an Apple cinema display used with the Apple adapter.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It sounds like you damaged something on the logic board in the process.
Did you encounter any difficulties taking the logic board out? Did you use a ESD wrist strap & mat? Unlike desktops & laptops you need to fully remove the logic board.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hi Dan
Thanks for your reply. Hopefully this is not the case. I placed the old ram (Had a 4 and a 1gb) back in, and things seemed to be running fine again. So I returned the 2-8 gb chips and just bought and installed a 2nd 4gig chip. So far so good.
Fingers crossed.
из
Добавьте свой ответ
Paul McCusker буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 134
