Fingerprint sensor not working water damage
I recently dropped my phone in water and after I dried it off the speakers worked fine and everything seemed perfect accept for when i tried my fingerprint again. I attempted to delete and redo the fingerprints but I had no luck. Any help?
Это хороший вопрос?
Оценка 2
1 Комментарий
After a glass of water fell on my phone the fingerprint sensor did not work despite my phone is fine but finger sensor not work , any possible solution ???
из
Добавить комментарий
3 Ответов
Выбранное решение
Unfortunately, the only solution was to get the sensor replaced by a professional which was a bit pricy. But my fingerprint sensor is working just fine now.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I tried everything but eventually put on radiator on a towel overnight and then reinstalled updated security software, switched it off and on and the scanner was back in my settings
из
Наиболее полезный ответ
Did you ever find a solution? Same happened to me.
Оценка 1
1 Комментарий:
из
1) You may clean your mobile and then play a high bass song on your mobile
2) then keep your phone work continuesly working for about 2 hours
3) as the processor gets heat up plat the song again to release the hot air inside your mobile then go to sleep with your mobile shut it at power of keep it off all night long and next day delete all your fingerprints then restart your mobile by putting it in flight mode add your finger print it will work I did the same after what happened to my phone
Оценка 1
1 Комментарий:
Same thing happens with my mobile it fall into toilet basin then I bring it out wash with soap and water then keep it on sun...for a day from back side still fingerprint was not working then very next day I kept it on sun for half days from screen side ..then it works perfectly then it use to work on past...
из
Добавьте свой ответ
Patrick De Castro будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 46
За последние 30 дней: 218
За всё время: 14,603
