My right bumper is not working when I press it.
The right bumper on my Xbox One controller is no longer working unless I press it a bunch and then it will MAYBE click. I need help!
Это хороший вопрос?
Это хороший вопрос?
I had this happen before, it was the detent had broken.
If that's the case, I would but one off ebay and save the broken one for parts.
Был ли этот ответ полезен?
I can’t find one it’s not on amazon either, are there any other places
If you press down the right trigger and blow into the the right bumper in the gap may 10 times then it somehow fixes it.
Unfortunately that does not work at all on it, tried that when it was suggested a long time ago.
This fixed mine, thanks.
This surprisingly fixed my problem. Thank you, you were god sent
quite surprised this worked
I had that happen, took the controller apart and found the bumpers were still intact. I think what happened was the metal bracket that holds the button in had become bent. What I did was apply a layer of super glue along the part of the bumper that makes contact with the button to give it a bit more length so it can fully press the button
tried some similar thing, now superglue is stuck inside the button on the board, fml
@asimdaud how did you do that
I don’t remember what I did 5 years ago to fix it but with super glue you have to be careful as it messed up the button
a couple months ago I had bought an Xbox elite series 2 remote for my birthday and was acting just fine. A couple weeks later my left bumper has become completely unresponsive when I press down on it. Anyone know how to fix this? I really don’t want to spend out on a new remote when the rest of it is perfectly fine :(
Try holding the bumper down and then blow into it. That may work it worked for me.
It also fixed mine
and it fixed mine to
you. have to restart consle wait 5 seconD's and it wrks
Unfortunately, this one just does not work.
im tired of dealing with this i might honestly just buy a new controller
i just blow into mine, still acts up from time to time. Also check for gunk in between the bumper and trigger, if there is any, clean it out with a tooth pick or pencil
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 62
За всё время: 72,623
5 Комментариев
Is it sticking or simply unresponsive?
из Aaron Bouchard
yes it wont do anything and I mainly use my right bumber for almost every game
из Deven Thompson
I have three controllers now and it’s !#^&^$^ me off, The first one just stopped working, the next one was working fine, until it was a bit unresponsive, but then it stopped working completely
из Triston titterington
I also have 3 with r bumper failure...one is now 3months old, that new ghost controller...top half is see thru...I can see it working just fine, all 3 controllers click just fine...its very frustrating
из Abducted Nightly
My rt won't work I keep pushing it I get no response.
из Avilamateo
