Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
1525вопросов Показать все
How to use multimeter to Diagnose ICs and other Board Components.
Hello Everyone? I'm looking for a little advise on board related problems. This is my case I have been working for a few years with iPhone Repairs mainly screen repairs and other parts replacements that do not need any board level repairs.However I recently started doing board repairs I have a Microscope , Hot Air Station , Multimiter , soldering station and most of the tools needed to do this work. But I have been struggling when diagnosing the problem specialty when it come to ics and checking voltage and looking for shorts and things like that. Any tips on how to use multi meter tools to check voltage , continuity and what needs to be checked to find out what the problem is.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Unfortunately, what you seek is beyond the scope of a simple answer on this forum. There is a lot to learn but most if it you can do on your own if you put a bit of effort into it.
IMHO if you are going to be doing board level repairs as a business, I think you should be investing some time and effort to understand at least the basics of electronics. Once you understand what a resistor, capacitor or inductor (coil, choke, ferrite bead) does and how they behave, you will know how to test them and whether or not it can be shorted or removed.
This is a good tutorial on how engineers deliver clean power to IC's. This is very relevant as the majority of the passives on an iDevice logic board are there for this specific reason. There are several articles in the series and they touch on capacitors and ferrite beads (filters). Another good source of materials is ElectronicTutorials. There are also some good youtube channels such as Afrotechmods, AddOhms and of course the EEVBlog.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
EC REPAIR будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 244
