Problems removing the oil pan
I'm having problems removing the oil pan, i have removed all the bolts but it's still catching on something, it's like something's going through the oil pan not letting it drop
Это хороший вопрос?
Это хороший вопрос?
@pounder , Clint, If all oil pan bolts are out and pan is loose, you are probably getting hung up by the oil pump sump tube. The engine will have to be lifted a few inches to get clearance for oil pan to drop far enough to clear the oil sump tube. 1st link pdf download Instruction links/video below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 3,183
