The Nokia 3310, released in 2000, is known for being incredibly durable.
Why is my phone not turning on?
The phone is not turning on. Not even the screen or the led lights. I don't have the original charger so I'm​ using a 4-6V charger with 800mA output. When i check the voltage of the battery, it shows slight increase after a long time. So i know the battery is charging. Yet the phone is not turning on. What might be the reason for this?
Это хороший вопрос?
Счет 0
7 Комментариев:
Are you sure your doing everything right? This is a 3310. They dont die.
Also what voltage are you measuring on the battery. And did the charger work with the phone before? And when did the phone stop working?
из
Mine stopped as well,as soon as I put New some card and 8gb memory card in it,now not even charging with original charger
из
I mean New version of Nokia 3310
из
Slav, This is for the old version. Also, where do you live?
из
Yeap,later I saw,that this topic for old version,and I'm in uk
из
Показать ещё 2 комментариев
Добавить комментарий
1 ответ
My phone went off with nokia sign on screen
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Nikhil Anilkumar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 2,571
