Where is the fuel pump
where is the fuel pump
Это хороший вопрос?
If I remember correctly on my 2005 its in the fuel tank.
Checked online and confirmed--its in the fuel tank. That unit combines the pump and fuel gauge sending unit and as I recall cost about $400.
Был ли этот ответ полезен?
It is in the gas tank. In order to remove it you have to drop the tank down
Can I cut through the back seat access panel
Nate Cox, you need to start your own question. This is from 2011 and will most likely be overlooked by our team of experts. Good luck
За последние 24часов: 4
За последние 7 дней: 9
За последние 30 дней: 21
За всё время: 3,662
