Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
Вопросов 20 Показать все
Small Black Square Rubber from Home Button area
When I took off the home button, a small black about 1/8 inch square rubber piece fell out. While gently peeling off the heated cable.
Can anyone tell me where this is supposed to go when I put the home button back on.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (4)
Наиболее полезный ответ
It goes over one of the two screw hole right under the home button.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Yup, @scottpine is correct. It is the small piece that covers the screw brackets attached to the bottom of the screen. The picture was fuzzy and I should have seen that so good catch.
из
Not too sure what rubber piece you are taking about with the home button. There is not rubber peices on the home button of the 7 or 7 Plus. Can you take a picture of the piece and where it came off and I can tell you what is it and where it goes?
Can you also confirm that you have an iPhone 7 that you are working with?
Оценка 0
Here is the picture
Оценка 0
2 Комментариев:
Did you ever find your answer? Same issue here. Fell out while removing glass (shattered to bits...)
из
Never did find where it came from. Whatever it is, it made no difference to the phone. Repaired many other i7 and never came across this rubber piece.
из
The black rubber piece may have come out of another section of the phone. It was probably dislodged earlier and was just waiting to fall out. I just had one fall out of my i7.
Оценка 0
Добавьте свой ответ
Joe in PA будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,498
