Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48вопросов Показать все
Why does my laptop not work unless it is plugged into the wall
My Toshiba P55W C5314 saids it is fully charged. The battery icon is indicated and does not show as any issues. But once I unplug it from the AC adapter it turns off immediately and will not power back on unless plugged in. It almost like my laptop is functioning like a desktop. Any advice?
Это хороший вопрос?
Оценка 1
2 Комментариев
из
I HAVE THE SAME PROBLEM, I HOPE SOMEONE CAN HELP ME.
My Toshiba P55W C saids it is fully charged. The battery icon is indicated and does not show as any issues. But once I unplug it from the AC adapter it turns off immediately and will not power back on unless plugged in. It almost like my laptop is functioning like a desktop. Any advice?
из
Добавить комментарий
1 ответ
Выбранное решение
It sounds like the battery is dead, you can find yourself battery health check software to confirm, but replacing the battery will most likely fix the issue.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Oak Cliff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 820
