iPhone 6 plus works only with original screen?!
hey something strange is going on. i did an iphone 6 touch ic repair and the screen was broken. first i tried to replace the screen with an aftermarket one. no image (there is a backlight) . so i checked the connectors (also the connectors on the board). the connectors are fine. so i took another screen and it dident work. i tested 4 screens. then i putted the original apple screen back on it. and it worked. but that one is broke so that is not an option. there must be something wrong with the voltages or something right? i changed the image driver. it dident work. also i checked al the caps around the connectors and they are all fine...
Это хороший вопрос?
4 Комментариев
Is it no image or no backlight?
из Gigabit87898
hey! it is no image
из thieske
I have the exact same problem and am stuck.
из Liidri
Did you solve this issue?
из Jehú Quezada
