Repair and disassembly guides for microphones.
The wires are not connected, need to reconnect
I opened the microphone and discovered that the wires have been broken from where they are soldered. Need to make the wires longer and replace. How ?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
It wouldn't cost you that much. You can acquire some solder, flux (that will help things go much smoother), wire and a soldering iron, for quite cheap. Even the desoldering shouldn't be too complicated.
Here's a video
https://m.youtube.com/watch?v=16X9IAc9bl...
I'll give you a list, from iFixit, or you can scour eBay and find the same things
[связанный продукт отсутствует или отключен: IF145-018]
This is "non-leaded" solder, that's the good stuff
Solder Leaded 63/37 Rosin Core
Tack Flux SMD291 no clean 5cc ROHS
https://www.google.com/search?q=radio+wi...
Make sure to "tin" the areas and wires, prior to installing the new wires. You'll want to add a dash of flux, then add some solder to the wires, then solder the wires to the board
Tack Flux SMD291 no clean 5cc (for lead-free applications) w/plunger & tip. Изображение
Товар
$13.99
Leaded 63/37 Rosin Core solder, great for repair and rework. Изображение
Товар
$19.99
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Eric Sokol буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 178
