Support and repair information for Beats Solo3 headphones.
63вопросов Показать все
Fixing no sound in one speaker on blueooth
I am having issues issues with the right side of my Beats solo3 wireless headphones. On bluetooth no audio comes out from the right side and the right side will only work if i jiggle the left side. Both sides work fine when using the aux cable for wired setup. What could be the issue?
Это хороший вопрос?
Оценка 4
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Plug in your auxiliary cord to your headphones to device, play some music, and if it works like that than take the auxiliary cord back out, turn on blutooth and both will start working again.
Был ли этот ответ полезен?
Оценка 2
8 Комментариев:
I did it and it didn’t work. Twice. Help plz!!!!
из
It didn,t work for me either
из
Didn't work for me either
из
Didn’t work for me either.
из
I know this is old, but i just tried this and it worked
из
Показать 3 больше комментариев
I have the same problem too
Оценка 2
If anyone is still having this problem I was able to fix my Beats Solo 3 Wireless issue with no sound on one speaker on bluetooth after I followed the instructions on this video: https://www.youtube.com/watch?v=kypDTpO_...
Hope this helps.
Оценка 0
1 Комментарий:
This doesn’t help at all.
из
It could be a loose or damaged connection, would have to disassemble and inspect to determine the correct issue.
First try a reset etc.
Оценка 0
Bruh I don't know what to tell
Оценка 0
1 Комментарий:
Yeah you might need new ones
из
Добавьте свой ответ
MrSnowyOwl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 38
За последние 30 дней: 101
За всё время: 45,592
