Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Earspeaker/Earpiece not working after screen replacement iPhone 7 Plus
Hello Guys,
I have replaced a iPhone 7 plus screen. After the screen replacement the speaker above does not work anymore. Everything else is working, front cam, proximity sensor etc is all working.
I replaced also the speaker and the flex with new one, but without succes.
Who can please help me out of this problem?
Thanks a lot.
Это хороший вопрос?
Оценка 2
1 Комментарий
did you try to put back the old speaker? what was the reason to change the flex and the speaker and not use the original ones?
из
Добавить комментарий
3 Ответов
Выбранное решение
Problem is fixed! It was a faulty front camera flex. We tried like 4 flex cables (with apple logo original), but only one worked.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
hope it is the same problem for me... Replaced an iPhone 7 Plus Cable Today and it got stock in the booting process, then took the original one, but now the earspeaker didnt work...
из
I believe I did the same thing today and all you had to do is barely hit the flex or cut it slightly I didn't even cut it what I did was is I somehow split it right at the part where the earpiece connects with 4 for gold pieces are,right at the right corner on the very corner I tried to lift it in the flex like split like basically when you peel off tape,going to try a new flex tomorrow and we'll see what happens
Оценка 0
Here's a picture of the damage
Оценка 0
Добавьте свой ответ
Nisay Atsu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 3,222
