Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66вопросов Показать все
Piece of memory card broke inside slot
Hello I inserted the memory SD card inside my canon 80d. It broke inside, what can I do?
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Выбранное решение
Siempremireya, Possibly shake the piece out with with card door open facing down, try sucking it out with a vacuum with small nozzle/crevice tool attached, remove battery and pick broken SD card piece out care fully with tooth pick/metal pin/surgical tweezers or if need be perhaps take into a good local camera repair shop and have them give an estimate to remove broken card piece. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
Оценка 3
You'll need to open up the camera to get at the slot. There should be disassembly instructions on this site.
Оценка 0
1 Комментарий:
There is no instructions. Also a link to the instructions would be useful.
из
This problem happened to me 5 minutes ago! I first tried to simply shake putting the slit facing down but it didn’t work. Then I tried vacuuming the piece that was stuck but it didn’t work either. Finally, I used a flashlight and a screwdriver and slowly pooled the piece off of the camera and eventually it fell to the flour.
The camera is still working just fine! so all it takes is a tool and some patience.
Оценка 0
Добавьте свой ответ
Siempremireya будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 21
За последние 30 дней: 62
За всё время: 3,568
