iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467вопросов Показать все
eSata Port on 27" iMac
There are people out here that would like to put an external eSATA port on our 27" late 2009-2010 iMacs. there is a spare one on mine and I would like to put one on my iMac. I have a27" i7 2.8GHz late 2009. I would like to upgrade the hard drive I was thinking to put a eSata in it and use the extra eSata in the unit but thought having an external eSata would be better. Also I want to upgrade the video cared two hold 1 gb of video memory.
can anyone help.
Since my last post, I found out the that there is a second eSata port on the 27" iMacs made in Late 2009 to current ones. where it is and what it looks like I Really do not know. Does anyone have taken apart a Quad Core 27" and have IDed the cables?
But for now I am saving up for the 3TB Seagate Drive and the 500GB Momentus XT. I going to put a 3TB HDD to replace my 2TB HDD (use it for my other 27" replacing the 1TB HDD) and place a 500GB Hybrid drive by Seagate the cost for the drive is about $120.00 plus the cost of the bracket to remove the DVD drive. The Seagate Momentus XT http://www.seagate.com/www/en-us/product... its a 500GB HDD running at 7200RPM with 4GB of SSD Memory. In Benchmarks it was 14 secs slower the a 512GB SSD Drive and almost 3 min faster then a stand 500GB HDD booting a 17" Macbook Pro.
As for the Answer about upgrading I cannot afford a MacPro it would cost about $4500.00 to set it up. My 27" Quad core was a present all I could afford at the time was a 27" i5. I have to save up my money every month to plan on upgrading. I just put 8 GB of RAM into the i5 so now I have 12GB of RAM. "Anyone need a set of 2GB Chips for the iMac and Macbook Pros.
So if anyone can find out were the second eSata cable is otherwise I will remove the DVD.
Thanks
Kristyanna
Это хороший вопрос?
Оценка 2
2 Комментариев
This question was migrated from http://meta.ifixit.com/.
из
Apple iMac "Core i7" 2.8 27-Inch (Late 2009) Specs
Identifiers: Late 2009 - BTO/CTO - iMac11,1 - A1312 - 2374
из
Добавить комментарий
3 Ответов
Выбранное решение
The best thing for a Power User is to get the correct machine. You really need to be in a MacPro where you can drop in four hard drives and get all the video power you want. You can also drop in 64 GIGs of RAM. Take a look: http://www.everymac.com/systems/apple/ma...
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
UPDATE 5/2012 Here's where you can get it done now: http://eshop.macsales.com/shop/turnkey/i...
из
Dear Kristyanna,
Unfortunately eSATA is not supported by any Mac at the time...
The only way to get eSATA on a Mac is to buy a MacPro install and eSATA expansion card inside.
The same thing being said about the video card... You got to live with what you bought...
There is no way of upgrading an iMac in the way you'd like to...The only way on getting those features would be a MacPro for you.
Kind regards,
deSteini
Оценка 0
1 Комментарий:
Kristyanna,
I think you are confusing eSATA (e for external) and SATA.
eSATA is currently only supported on MacPros with and expansion card.
As for what you probably mean is the internal cable.
It is true that there is a second cable and space for a SSD drive in the most recent iMac 27'.
However, that is only true if you have configured your iMac to hold an SSD and a hard drive when you bought it.
Upgrading later on is not possible.
из
I know this post is old but others might come here for an answer. LaCie just released a Thunderbolt to eSATA adapter that works great. It costs $199 but its a great solution for a problem many of us have without a Mac Pro. http://www.lacie.com/us/products/product...
Оценка 0
Добавьте свой ответ
Kristyanna будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 7,110
