Is there a way to reflash the EFI/ Bios on my iBook?
ibook G4 12" 1.07 GHZ A1054 EMC 1916Q
I have an ibook here that I have had for a few years (2) and got it for free. Ran great for a while till mid last year when it started giving me problems.
When I start the machine it will do its normal boot up until it just freezes. It will freeze in boot no matter what I do. SMC/PRAM reset, let the charge all the way down, completely charge and let discharge again, I am wondering if theres an arbitrary white list of hard drives for these machines but it has used the drive that is in it before.....
When I take the hard drive out, it will go just fine. Once in a while it will actually load with the drive inside but it just won't see it. Just now I reseated the connection but it doesn't appear to do anything.
Thanks!
Это хороший вопрос?
Оценка 0
1 Комментарий
Добавить комментарий
1 ответ
Наиболее полезный ответ
Replace the Hard Drive
Pre-Installed MacOS: X 10.3.3 (7G51) Maximum MacOS: X 10.5.8
Standard Storage: 30 GB HDD Std. Storage Speed: 4200 RPM
Ultra ATA/100
http://www.everymac.com/systems/apple/ib...
iBook G4 12" 800 MHz-1.2 GHz Hard Drive Replacement
Universal Drive Adapter
https://www.amazon.com/ATA100-5400RPM-Up...
Universal Drive Adapter Изображение
Продукт
$24.99
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I have done this numerous times.
из
Try the current internal drive hooked up externally and see if the problem persist. You'll either an external ATA enclosure or a Universal adapter.
из
Добавьте свой ответ
ph4nt0m будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 125
