CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
295вопросов Показать все
No Display and Repeating Charge Chime
Hello, I have 2 iPhone 4's on Verizon. I wanted to swap the screens on them since one is in locked and the other one is shattered. After a very long process of lost screws and frustration I finally have the good screen on the good phone. The only thing it does now is show up in iTunes and keep making the charge chime. I have put the other board in the housing and it does the same thing. I have even tried the cracked screen on both boards and the same thing happens. I would really appreciate it if you could help me out.
Это хороший вопрос?
Оценка 2
2 Комментариев:
Sounds like either board damage or both the screens got damaged from improper installation.
из
I have the same case, except my screen is shattered. The screen worked like that though, and my phone is a little rough, any fixes anyone?
edit: havent replaced the screen yet, its just like this
из
Добавить комментарий
1 ответ
Very unfortunately, Dylan, your 'good screen' is probably bad. Exactly what you observe (no display and repeating chime) indicates a broken or missing screen. You have my sympathy: replacing iPhone 4 front/screen assembly is onerous. Too I broke an otherwise operational screen, by bending its cable.
See Wiki page: iPhone endlessly repeats the "power supply accepted" sound or vibration.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Dylan Mclaughlin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 290
