Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
1525вопросов Показать все
Screen discoloration in top right corner of iPhone 6 Plus, please help
I replaced the front panel on an iPhone 6 Plus last night. I tested the LCD before installing all of the components (front camera, speakers, home button, etc.) into it, and it seemed to work fine. I even did one more test run before I closed the screen to make sure all of the cables were connected well, and it worked perfectly. When I closed the screen, however, a bright spot had appeared in the top right quarter of the phone. I have had two other 6 pluses with identically shaped and positioned bright spots, so something I am doing wrong must be causing this. Please help me with any information you know.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
It would be helpful if you posted a picture (you can add it to your question).
Generally speaking, white spots are caused by pressure. So if you have a bright spot in the top right corner, look at the camera and screen bracket area for something that isn't installed or lined up properly. It could also be a batch of poor quality screens where there is some dust or something else sandwiched between the LCD and backplate (this would be a very small white spot though).
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
I had a white spot also. It was the battery pertruding slightly on the upper left edge (original battery and screen). I solved it by lightly pressing down the edge of the battery with the flat end of a plastic spudger.
из
i think it has no solution take it to apple authorized centre
Оценка -1
Добавьте свой ответ
Garrison Bates будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 6,112
