Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
431вопросов Показать все
Cant find an answer I found before?!
looking through your database I found a detail guide to the use of Disk Utility on how to format the new HDD i'm about to install but i cant seam to find it any more can some one point me to it pls.
Also will putting an larger HD than I took out of the imac be a prob. i.e. will the sys bios see it with out in put from me? thanks for your help.
Это хороший вопрос?
Оценка -1
1 Комментарий
Thanks for your help I also found the art. I was looking for bookmarked it this time lol just got a email from you guys that my drive is on its way I'll post up the out come after I install it and i am up and running.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi Bryan,
1. Boot from Install DVD
2. Choose Language -> and wait
3. Click on top Menü -> Utilities
4. Click on Disk Utility
5. Choose new HDD on left side with the GB in it
6. Choose on the right the erase pane
7. Choose "Mac OS Extended (Journaled)"
8. Click Erase.
The new Disk is now formated and ready to use.
You don't need to partition the HDD if no partition is created yet. Erase is absolutly fine.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Set it to one partition
из
Добавьте свой ответ
Bryan Seneviratne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 536
