How to hard reset with no original controller
My ps3 is old I guess you could say now. I have a ps4 so I really play that and not my 3. But I do get on my 3 when I sleep at night. Like most people get on Netflix or YouTube when night hits. I'm one of those people. But my ps3 file corrupted cuz it's Prolly to old. I tried to hard reset but the issue is I use a wired controller and not the original kind. So I can't control it to reset my ps3. Do any of you know how I could find another way to fix this. Cause I don't wanna buy another controller just to get on YouTube and netflix. I will play it from time to time. Like gta 4 or kingdom hearts. But that's it. So could someone please tell me a solution
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
If it was corrupted, you should take it out and format it, and start fresh. Use the below guides to do so:
Hard Drive Restore
PlayStation 3 Hard Drive Replacement
Hope this helps!
PlayStation 3 Изображение
Инструкция
Hard Drive Restore
Сложность:
Легко
4 - 8 hours
PlayStation 3 Hard Drive Изображение
Инструкция
Сложность:
Модерировать
5 - 10 minutes
Был ли этот ответ полезен?
Оценка 1
6 Комментариев:
How do you get around the set up without the controller?
http://www.wikihow.com/Reset-a-PS3
из
@mayer One' should be able to set it up using the USB controller. If not, the OP must barrow a wireless one.
из
Then your answer doesn't solve the issue of not having a controller.
из
@mayer I don't understand. The OP can't reset because he doesn't have a wireless controller. My solution shows how to using his USB controller. I don't what you mean "the issue of not having a controller" when the OP does have a controller, just not a wireless one.
из
have the same problem aftermarket remotes are touch in go sometimes they works sometimes they dont ( SYSTEM RECOVERY MODE) it could be several different reasons why , i bought a cheap ass one with cord just for rebooting systems that are stubbern
из
Показать 1 больше комментариев
Добавьте свой ответ
Jalen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 83
За всё время: 23,867
