The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Why is my dash brake light on when driving?
my dashboard brake light stays on while driving the car. I have good brakes because my mechanic checked them.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
christy, it means one or more of the following, the brake fluid is low, the parking brake lever is either up or the circuit for the parking brake switch is shorted, or if the battery light is also on, the car needs a new alternator. Also check your rear brake lights and make sure they are all functioning. Since we are talking brakes here,you should have a mechanic check it out for you. Hope this helps a bit and good luck to you.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
christy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 37
За всё время: 6,382
