Шестое поколение Honda Civic было представлено в 1995 году. Оно сохранило лучшую в своем классе управляемость, так как, подобно четвертому и пятому поколениям, оснащалось передней подвеской на двойных поперечных рычагах — передовой независимой подвеской, вдохновленной гоночными разработками Honda.
Idle issue need help UPDATE
UPDATE.....All sensors have been replaced on the throttle body, coolant is full. What else can cause this idle issue?! Help cause with the exhaust I have it's really annoying hearing the rev go up and down in town and traffic
Hey y'all, I replaced my iacv and my tps in my 99 civic and it's still idleing/Reving up and down, any ideas why? I feel kinda dumb. I rebuilt the whole engine and that's the only issue I have. It's a d16y7 with a y8 throttle body. The y7 tb did the same thing..help?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
@tanker151, Travis, Have the car scanned for trouble codes as a first step, could have an error even if engine light not on. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track.
Could be low coolant, air in the cooling system(bleed system), faulty temp. sensor, vacuum leaks(spray some aerosol starter fluid around base of intake/ throttle body, vacuum lines/etc.), if engine rev's even out or change noticeably there is the leak. Recheck a dirty/sticking IAC., is new TPS calibrated(link 1 below). Check the 2nd link for more trouble shooting tips. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=GL8snGK_...
https://www.youtube.com/watch?v=L788jKEV...
Был ли этот ответ полезен?
Счет 3
Mine does the same thing, up and down reving on idle, I have a 2000 honda civic lx d16y7 I changed everything from the throttle body sensors up to the PVC pipe and still doesn't the same thing, I looked all over for air leaks and nothing loose or broken, till this day I'm still looking for clues
Счет 0
1 Комментарий:
Somthing that I did to fix it was a bleed the coolant and it fixed it
из Поделиться
Its most likely the fast idle valve, wich is attached to the throttle body, if its leaking air after the car is warm , causes this
Счет 0
Добавьте свой ответ
Travis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 72
За все время: 14,038
