Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Mower runs but has small backfires when accelerator moves up.
Craftsman 917.289220 Mower runs but has small backfires as throttle is moved up. Also loses power as this happens.
Это хороший вопрос?
Оценка 1
3 Комментариев
Forgot to mention, air filter is clean, oil ok, fuel flows freely through filter.
из
@bvilleeer sounds more like a carb issue than an ignition issue. What make and model is your mowers engine?
из
Not sure oldturkey03. Briggs 21hp
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
A spark plug that is damaged, worn, or has an improperly set gap between its electrodes creates a weak spark. As a result, the fuel may not ignite in the cylinder, but it might ignite when it reaches the hot exhaust muffler. The result is a loud backfire. Poor spark also results in a mower that runs unreliably.
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Changed plug. Same result. The plug I took out was black with carbon, I guess.
из
Your plug sounds like it is getting to much gas. Here's how to read a plug:
https://www.ngksparkplugs.com/about-ngk/...
из
It is dry fouling according to the pic. How do I remedy this?
из
Добавьте свой ответ
Brian clark будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 30
За всё время: 6,920
