Vertical lines over LED tv
I moved my 50" 4k SEIKI to her house and it now has vertical lines on display. I did bend a video input connection as I took off coax antenna cable. Looked at that connection on board and it does not seem to be shorting anything.
Should I try to replace that board? Could cable connections have come loose?
There are several versions of this tv. I see all boards listed for sale from one with broken screen, but the one I damaged looks different. Could I just replace all with new (keep same screen)?
Это хороший вопрос?
Оценка 0
1 Комментарий:
well my seiki shows black and lines what can i do to fix it before my perents figure out
из
Добавить комментарий
1 ответ
I'm not an expert on televisions, but this looks like potential LCD damage. I see very similar lines when there is damage to an LCD in a phone or a tablet.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
there is no damage visible to screen
из
The damage could come from very tiny cracks in the LCD. They may not even be visible under the glass
из
Добавьте свой ответ
Rich Hrad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 1,263
