The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248вопросов Показать все
I dropped it and the screen is cracked.
Will that cause it not to work? It will power on but I can't see anything
Update (07/15/2017)
Ok thank you very much for your help. I thought when there is no display on the screen it meant the LCD was broken is this true?
Это хороший вопрос?
Оценка 0
1 Комментарий
@shirleyb that is correct. I’ve seen more Galaxy’s with broken LCD than screens, usually a bit easier to spot the damage after wiping the screen and using a flashlight.
из
Добавить комментарий
1 ответ
Выбранное решение
@shirleyb , sorry to hear about your phone. The phone most likely powers on and will function normally but when the screen is damaged it will not display anything.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Shirley Bennight будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 57
