BlackBerry Priv - это первый смартфон от канадцев под управлением операционной системы Android, который сочетает в себе безопасность и хорошую производительность.
23вопросов Показать все
Wi-Fi Mac adress stuck at 02:00:00:00:00:00
Hello everyone,
For a few days now, i can't activate le wi-fi on my BlackBerry Priv. When I go in the option to activate the wi-fi, it keeps loading and it show no wi-fi in the list. After a few research, i've discover that the MAC address for the Wi-fi is stuck at 02:00:00:00:00:00.
Here is a liste of what i've tried to solve the problem (with no sucess):
1- Reboot the phone a few (lots of) time
2- Pull the sim card out, no wi-fi
3- Replace the sim card
4- Let the battery drain until the phone shut-off and charging it again
Hope someone will be able to help me , cause i kind of like this phone :(
Это хороший вопрос?
Оценка 2
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Hi Stephane,
Can I ask if the phone was purchased second hand? Also, is the phone Rooted?
If so I would recommend wiping the phone fully, if that doesn't work is flash the firmware back onto the device.
It seems that the MacAdress is either Spoofed on a software level or someone has tampered with the phone's root files...
Thanks!
Ben
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Hi Ben,
thanks for the quick reply !
I've purchase the phone second hand directly fron my provider and it as not been rooted. So I think the next step before heading to the repair shop is to do a factory reset.
Stephane
из
My iPhone 11 shows the same MAC address. Should I be concerned and if so, why?
из
Hi Ben my phone is the same my Mac is 02:00:00:00:00:00 no matter what device I use I need help
из
My iPhone 11 shows the same as well as my 6s. Should I be concerned? If so, why?
Оценка 0
Hi Stephane, were you able to solved it? I have a One Plus 2 phone with Android 6.0.1 and weeks ago just happened that to me and I do not know how to fix if.
Regards.
Оценка 0
Hi guys my priv is the same. Just shows loading but cant switch on the wifi and this problem drains battery so fast bcuz loading continues all the time
Оценка 0
Добавьте свой ответ
Stephane Pepin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 29
За всё время: 9,782
