Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
My touch screen doesn't work
I have tried a force reboot but it still doesn't work I need help!!
Это хороший вопрос?
Счет 0
1 Комментарий
Hi Taza, you have already posted this question a few minutes ago. I would encourage you to delete one of these to keep the Forum uncluttered.
из
Добавить комментарий
4 Ответов
Выбранное решение
sounds like a bad digitizer consider replacing or invest that money towards a newer iphone
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I have replaced the screen so do you think i need to get another one ?
из
Этот ответ изначально был на другой вопрос.
Is this after a screen replacement the touch didn't work, or did it just stop working the original screen? If it just stopped working, then you will probably need a screen replacement.
Счет 0
1 Комментарий:
I had replaced the screen because it was cracked
из
Replace the screen.do not try it yourself if you are beginner.iphone 4 screen replacement need some set of skill to replace.
Счет 0
2 Комментариев:
I have replaced the screen but it doesn't work
из
ok,is there any repair shop near yourplace? if yes ask them to bypass their screen a few to make sure that it is really logicboard problem. sometimes parts we bought are defected/malfunction during shipment.
из
The LCD may be bad. Have you tried a new screen or "tester" screen?
Счет 0
Добавьте свой ответ
Taza буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 91
