Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
HELP! Vertical lines in low light camera!
Hey everyone, I bought an iPhone 6 64gb from my friend and everything seems to work fine. However when I am using the camera in low light there are some vertical lines that appears on the pictures as well as the screen while taking it. On day light the camera works fine.
I have also updated my phone to 10.3.3, but still no luck!
Please let me know how do I fix it. I have searched it around the web but no related topics.
A quick response would be highly appreciated.
Это хороший вопрос?
Оценка 0
2 Комментариев:
BUMP! Anyone?
из
hey, I have the exact problem. did you get it fix?
из
Добавить комментарий
3 Ответов
As you try to change the camera ??
Был ли этот ответ полезен?
Оценка 0
4 Комментариев:
No, I didn't.
If I buy the camera from this website and replace it, will it workout? And be of the same quality of a normal iPhone 6 camera? I'm sorry if I sound dumb!
из
And when you raise the brightness what happens
из
If I use the flash in very dark places to take pictures, this problem doesn't occur.
Screen brightness doesn't affect the situation on either set to high or low
из
try to change camera back
из
I have this kind of situation too. How did you fixed this problem to your iphone? Someone saying try to open the iphone and unplugged the connectors and put it back again. Dunno if its true :(
Оценка 0
Have you tried taking a pic in low light? Take one, and if the lines are in the photo, it's a camera issue. If there are none in the photo, it's a display issue.
Оценка 0
Добавьте свой ответ
Arbab Rehan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 9,369
