Released in 2006, identified by model number PP20L for e1505
16вопросов Показать все
Good source for a Express card 16GB SSD under $30
My laptop has bad overheating issues at the HDD because it's constantly running at Max load. I need a 16 GB expresscard SSD which would be just enough for Ubuntu. Does anyone know of a good source for a SSD under $30? I'll never use my expresscard slot anyway, so this may put it to use. It's a 54/34mm slot. Or an adapter solution. Thank you.
@danj @mayer Anyone?
Это хороший вопрос?
Оценка 0
1 Комментарий
Anyone? Anyone?
из
Добавить комментарий
2 Ответов
Выбранное решение
@pccheese - George, I doubt you'll find one for so little. How about a micro-drive like this: IBM 1GB Micro-drive
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Alright, thanks. Do you know if I can use my wireless card slot for an SSD?
из
I doubt it as the needed driver may not load
из
I found the reason my HDD was overheating. In the BIOS, there is an HDD option for quiet, performance, and bypass. I suspect the performance mode forces more voltage that this cheaper HDD can't handle, and overheats. I put this settings on bypass and now the HDD stays much cooler.
Оценка 1
Добавьте свой ответ
George A. будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 280
