Why F - 28 shows up on the display and door not opening
Why F -28 flashing on the display and door not opening
Это хороший вопрос?
Это хороший вопрос?
shantapanchu a F28 error code is a common problem indicating that there is a communication problem with the central control unit. Any error code can be caused by a electrical anomaly. try to reset your washer. This reset might work but will depend on your specific model. To clear and restart the control follow the these steps:
Unplug your washer for 10 minutes.
Reconnect the washer
Press the Pause/Cancel/Stop button twice to clear the display.
Let us know if this helped and give us your washers complete model number.
Был ли этот ответ полезен?
W10007190 is my model number...nothing is working...really need my cloths.
how to find model number
Mine did the same thing. Ran diagnostic test and stopped at c02 time with error code F28
Didn't work.
Had the same issue! Mine was a simple door malfunction. I unplugged the washer power cord; plugged it back in. Then I opened and closed the door a couple of times and turned it back on. Seems to be working fine now. Good luck!
whirlpool duet the door still not open and -door closed -blinking and every time i push the power a sound like alarm goes on for few seconds like tin-tin-tin...
My washer model # WFW9200SQA1O
My washer is flashing F28. How can we fix this
I already follow your instructions to unplug the power cord from the outlet for 10 minutes and nothing happened.
My washer is a Commercial Duty Washer from Whirlpool and don't have a Pause/Cancel/Stop button on control panel.
The model N# CHW9060AW0 please need help.
702 559 3964. JC
jcresolution1000@gmail.
I have whirlpool diet sport washer.F28 error. I have unplugged it., pushed pause/ cancel button but the door still won’t open. I just want to get my clothes out. I’m buying a new one
Hi @wendyrohr,
What is the model number of the washer?
I have Whirlpool duet steam washer that won’t wash clothes and had F28 code. I’ve done the restart. I’ve unplugged for ten minutes and tried again. I took too off to see if any central control unit wires unplugged. I unplugged and repligged those wires. It still starts then stops with error code and door won’t unlock. What else can I try to fix it? Model and is WFW9550WW00
If you need to unlock the door to get clothes out like me, I took removed the bottom panel and was able to reach a pull tab that releases the door lock. The instructions to do this were located in a diagnostic manual in a sleeve inside the machine. I am getting the F28 code, happened mid cycle with my stuff still in.
За последние 24часов: 7
За последние 7 дней: 46
За последние 30 дней: 202
За всё время: 27,994
2 Комментариев
What’s the question?
из Dorethea Massey
What’s f02 mean and blinking water still in it won’t spin
из alaura_rhodes
