Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
iPhone 5s battery drain in standby
hello everyone
sorry for my bad english
i have problem with my iphone 5s IOS 10.3.2
Battery Usage and Batery Standby almost have a same time
When in standby battery drain quickly 3-5 hours and my phone so HOT
When i used the phone battery usage 6-7 hours
but charging time is normal 0% to 100% in 3 hours
I have replaced the battery 3 times with the new one but still same
Restore with DFU and setup as new problem still same
Is there a solution to my problem??
Thks
Это хороший вопрос?
Оценка 0
Добавить комментарий
5 Ответов
Выбранное решение
If several known good batteries are used and you still have the same issue in stand-by mode + heating up of the device, then you may have a board level defect, such as a short (this would consume power and warm up the phone) or a defective chip.
Also, 3 hours to fully charge your iPhone is not normal. It should be way less than that. This also converges with a short since a short will consume part of the power coming through the charger, and delays the filling up of the battery.
Finally, something makes no sense: how come in stand-by mode you get 3-5 hours of autonomy, and while using it you get more (6-7 hours)? Are you sure?
Anyway, I would try to isolate the issue before concluding that it is a board level issue.
- Look at Settings>Battery>Battery Usage. What are the apps using up the most %? Last 24H and last 7 days?
-Also try and turning Airplane Mode on. Does it improve? If yes, leave Airplane Mode on, but turn Wi-Fi on. Any change?
Report your findings here if you'd like us to follow up.
Был ли этот ответ полезен?
Оценка 4
ill be quick with this one.
suspect power ic which is main board fault so fairly expensive to have repaired .
HOW YOU CAN TEST
1. disconnect battery
2. plug phone into mains with battery disconnected
if apple logo does not appear after a few seconds then suspect power ic , changing battery will not cure this as main board fault.
i would start with that first before exploring other avenues
Оценка 0
as far as I know no iPhone will boot up without a battery connected. Am I wrong?
Оценка 0
1 Комментарий:
Yes you are wrong. You need a battery to boot it completely. Once it is booted, you may for some models (may be all?) disconnect the battery while it is still connected to the charger, and the iPhone would stay on.
из
Good morning have gone the the answers which were well explanatory.
My own iphone 5s when charging it goes to sleep mode and to put it on i have to hold the power button and the main menu button simultaneously for like 2 - 5 minutes before it comes on.I have just changed the battery but still the same problem.Kindly help me out with a solution this solve this problem
Regards
Thomas
Оценка 0
simple solution is do not buy Apple products, I have two mac air laptops both only 1 years old, one of them has to be repaired by replacing mother board, the second one is playing up. My iPhone 6 is has issues, and iPhone 5s has the battery issue, only yesterday replaced battery which didn’t help. Shall never buy apple products again.
Оценка 0
Добавьте свой ответ
nankae будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 9,652
