Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
369вопросов Показать все
Will rubbing alcohol damage my LCD?
I'm looking to replace the front glass screen of my S7 Edge and the last thing I need is a damaged LCD. I need to remove the adhesive layer over the LCD and I would like to know if rubbing alcohol damages LCD so that I can avoid at all costs. Please let me know!!!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You really don't want to use rubbing alcohol. It's not quite the same as isopropyl alcohol. While it is mostly comprised of isopropyl alcohol, bottles labeled as rubbing alcohol commonly contain other ingredients such as dyes and perfume oils to give it a less intense and more diluted smell compared to 91% or 99% isopropyl.
For what it's worth I highly advise not attempting a glass-only repair on your phone unless you have prior experience with the processes involved. Even individuals who have been doing display refurbishing for years have difficulty with the Edge models.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Correct, I really opened a can of worms replacing a lg4.
из
Добавьте свой ответ
Larry Zurita будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,616
