My iPhone 7 keeps showing the start-up apple logo on loop?
My iPhone 7 suddenly turned off and went into an endless loop of the start-up apple logo. It has been doing this for hours and nothing I seem to do helps
Это хороший вопрос?
Это хороший вопрос?
hi
Follow my steps to fix it
Download iTunes on Mac or Windows -> Connect your iPhone to the computer -> hold Volume Down and Power/Lock button and leave the Volume button after 10 seconds but keep holding the power/lock button-> a message will appear on iTunes telling it needs to be updated or restored -> Tap update -> it will then download an update file -> tap restore -> iTunes will automatically restore and fix your iPhone -> If that doesn't happen I prefer contacting Apple Support.
if not you try this way
https://www.facebook.com/notes/ubrakeifi...
take note if itsstill same might be your battry damage if your phone on warranty just send for warranty eazy
Был ли этот ответ полезен?
If you have opened this iphone before, the problem could be from a loose connection with battery or screen connectors.
You can easily fix this by disconnecting and reconnecting the screen and battery.
Also could be a faulty battery, try replacement.
If you have not opened this iphone I suggest not opening it as doing so will void your warranty (If you have one). In this case it is most likely a simple software fix with connecting to itunes.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,328
Can you give us more details like any other problems before this incident like problems with the battery or if the phone was dropped or water damaged?
из Diego A
There's hasn't been any problems with mater damage or battery before. It has been dropped before, but not recently
из J Carey
