Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97вопросов Показать все
Click wheel electronics transfer or replacement
Hello!
I decided to refurb an old iPod 3rd generation, as I like the buttons above the wheel.
I've already swapped out the hard drive and battery, and decided to go the full hog and replace the front panel as well, as the screen was a bit scratched up.
I ordered the front panel, but didn't quite realise that the electronics were separate. There is no guide on how to remove the actual electronics, so before diving in and probably destroying everything, I wondered if anybody had any advice? Anything at all would help.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Updating this as I figured it out myself, and hopefully this may come in useful to somebody down the line who is searching for the same answer.
Basically, the electronics are just held on to the front plate with some adhesive, and a couple of white plastic 'posts'. To get it off, I used a large (plastic) spudger to loosen around the edges, and then pulled the whole thing off from the top end. You want to make sure you are careful, as the electronics underneath are metal - and the PCB could snap if you are too rough. Replacing these in the new iPod is as simple as swapping them over.
For some other tips that weren't obvious when I searched:
1. Restoring on a modern Mac is almost impossible, even with FireWire. The best option is to get a Windows XP Virtual Machine and restore using USB. The iPod will then work on your Macbook with USB fine.
2. If you upgrade your hard drive to an 80gb version, make sure you have the 30 or 40gb iPod, as the 20gb's back plate is not deep enough to accommodate the 80gb.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
Thank you! I was wondering how the electronic pcb came off of the faceplate as I have to swap mine as well. I'm glad I discovered your post!
из
Use lots of drops of Isopropyl Alcohol to soften the glue (make the job much easier & less destructive)!
из
Do you also do that to the donor board off of the replacement faceplate and just transfer it? Does any other glue need to be added or will the old stuff work? Thanks!
из
Добавьте свой ответ
Clicky Steve будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 136
