Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Anyone know where I can buy iPhone 7 parts (CPU,BB,boardbad) cheap?
As the title says.
I need CPU and other components for my logic board and I need websites to buy them from. I would like a chines website but Im okay with what I get :)
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hello Kappa. Is this related to your previous question on iCloud locked devices? As I mentioned, there are several main components that are "keyed" together. That means somewhere inside, they share a similar key, or serial number if you will. There are ways to program the NAND and EEPROM but not the CPU.
What that means is that you can't just buy a CPU or a BaseBand IC and expect to change it on another device. You have to replace all of them (CPU/NAND/BB/EEPROM and Home Button) at the same time and they all have to come from the same, non-iCloud locked device. This is not like replacing a Tristar or MESON IC.
Some places do sell sets based on the device you are trying to unlock; you're best bet is to look at Aliexpress. However, I don't see the point when you could just buy the working logic board instead.
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
You cannot usual solder on or disassembled the tiny part the only thing damage is the scans is home button is very sensitive send in for the warranty rather that taking risk thy is not worth unless otherwise , most parts are embedded so no point on this
Оценка 2
Добавьте свой ответ
Kappa Keppo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 116
