The sound on my computer works. The sound on other browsers work as well. The only place the sound does not work is Chrome. This has happened once before but I was able to resolve it. This time, nothing seems to be working.
List of things I have already tried (in no particular order):
Restarting Chrome
Restarting computer
Resetting Chrome settings
Clearing cache and cookies
Re-installing Chrome
Going incognito
Disabling/removing extentions
Using the software removal tool
Troubleshooting
Using guest profile
The only thing that has been suggested to me that I have not yet tried is using Chrome Beta and Chrome Canary. I will eventually try them if nothing better can be suggested to me. I would prefer them to be a last resort though, as I do not want to risk any bugs.
As for which version of Windows and Chrome I have, it's Windows 10 and Chrome 60.0.3112.101
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
24 Комментариев
i have tried so many things but can not resolve muted sound on some live streams , when i try to open from a bookmark ie and firefox works 100%
always great to see users explaining it instead of saying something like "figured it out" as that helps no users who may have the same problem. good job!
if you had a secondary or tertiary computer screen that played audio , and you made it so that sound comes through that screen, then you either do not have that screen anymore or something shifted around in the updates. go to “App volume and device preferences” and make sure all of your chrome is set to screen you want, and not trying to play out of a device that is no longer hooked up to the computer slash shifted back to default with the last update.
my problem was that, if i opened chrome on a page with sound, it would play fine, but if i went to another page or reloaded that page, the sound would stop playing. All other sound worked fine in all other browsers and the computer itself. only when i went from one tab to another with sound, or loaded a page with sound that the browder didn’t open on, or went to another page, then the sound would not play anymore, and i didn’t understand the problem. i’ve tried everything from clearing cookies caches, updating drivers, looking through chrome settings and a bunch of other junk that DID NOT WORK. if you have this same problem. this has been going on since february… when i moved and broke the adaptor to my old tv as a secondary screen. didn’t know this was the problem until now.
App volume and device preferences, then look through the apps that actively use sound (system sounds should be there for reference). Chrome appears and disappears in this list when it’s open and when sound is playing, so if it’s not there, go to a page you know will have sound (system sounds should be there for reference) then app vol + device pref, and switch the Output selection to whatever screen or audio device for whichever screen/speakers you want the sound to come from, and that SHOULD fix it.
no guarantees. but this is what fixed mine. and i know i got it because the sound, that hadn’t been playing before, suddenly started playing fine the moment the audio for output was shifted to my default speakers.
22 Комментариев:
Searched for so long for this. This is what worked!
Though a very specific problem, this has been the only answer to truly help me out. I had never thought to be using the app volume and device preferences, considering I was using the Sound Blaster Z control panel and EarTrumpet.
Thanks for not posting another lol just unmute Chrome answer and actually providing a detailed answer with a profound sollution, along with a useful screenshot. You're a life saver!
It is possible Chrome was deactivated at your Windows Sound-Manager.
Go to the task bar (mostly at the right side of the bottom), right click on the Sound-Icon, open the the option "Volume Mixer" and check if Chrome is muted there.
27 Комментариев:
No, that is not the case. Thank you for the suggestion though.
I finally got mine working!! Here is what I did....
go to the Chrome "settings" in the 3 dot drop down, scroll down and click "advanced", under "Privacy and Security" click on "Content settings", scroll down to "Sound"........mine said "mute sites that play sound", I clicked on the arrow and clicked the on/off slide button and it changed to "allow sites to play sound" it also said (recommended)......and, apparently you can add sites that are "allowed" or "muted"
15 Комментариев:
I should add that I closed Chrome and then reopened it to be sure the new settings took .....
I had the same problem with no sound from Chrome. Didn't appear in the volume mixer. Wasn't muted. The thing that worked for me was turning off hardware acceleration whatever that is.
Click on the 3 vertical dots in the top left of the screen.
From the menu click on Settings.
Click on Advanced.
Then click on System.
Turn off the toggle switch for "Use hardware acceleration where available"
Another solution if you are on win 10. open volume mixer, then open the tab that dosent have sound, it will probably show up on the mixer, and it should be on min level. Once its like that, adjust it to max then its okay now.
I hope this helps to those who still has this unsolved
2 Комментариев:
How do you get to Spatial Sound option? Wondering if it's there on Win 8.
Bahamas Beaches, your suggestion worked! I believe Spatial Sound was a new feature I got in Windows 10 after an update last night. And it was off by default. Usual Microsoft dumbness.
8 Комментариев:
Thanks @almodaffar didn't even realize I muted it a while back and forgot. I tried a bunch of other things, including updating flash, turning off all Extensions to no avail until I read your solution. One of those head-slappers.
This suggestion is unbelievably simple but took several hours to find it! Who knew? Almodaffar solved it: Right click on an open chrome tab then select unmute site
Right click on the tab, select "Unmute Site". then click the Muted Speaker if it shows up on the uTube site or whatever you are trying to watch/listen to.
The issue is not just Chrome, but how you update Chrome. Go to the settings of Chrome and go to the about section. That's how you actually update Chrome. Not just by installing it all updating with the install. You have to go to the Settings. And then the about section so the update initiatesThe issue is not just Chrome, but how you update Chrome. Go to the settings of Chrome and go to the about section. That's how you actually update Chrome. Not just by installing it all updating with the install. You have to go to the Settings. And then the about section, so the update initiates.
2 Комментариев:
lmao thanks so much for this. THIS IS THE SOLUTION. I clicked on the 3 DOTS then WENT TO HELP --> ABOUT GOOGLE CHROME, updated then relaunched. Trash browser I restarted 6 times and it didn't update it then...
Check Volume Settings: Ensure that your system volume is up and not muted. Also, check the volume settings within Chrome by right-clicking the tab and selecting "Unmute site."
Restart Chrome: Close and reopen the browser.
Check for Updates: Make sure Chrome is up to date by clicking the three dots in the upper right corner, selecting "Help," then "About Google Chrome."
Clear Cache: Go to Settings > Privacy and security > Clear browsing data, then select "Cached images and files."
Disable Extensions: Some extensions might interfere with audio. Disable them and check if sound returns.
If the problem persists, consider restarting your computer or checking other applications for sound issues.
We were having a quirky sound problem in Chrome. Ads would play at regular volume, then the content would barely be perceptible with headphones (though fine on laptop speakers).
Opened a Firefox browser and sound played fine. Then went back to Chrome, and sound played fine. Problem gone!
For Discord users, this is possibly the reason why you cant hear anything from your Chrome browser videos.
Hello,
this solution completely worked for me, as discord automatically muted Chrome after I messed with some mic and audio settings. Took me a bit of troubleshooting to figure it out, its actually a feature which enables discord to reduce or completely mute the sound from other apps while you or someone else is talking. If you change the settings of discord before you got the audio problem on Chrome, you know why now.
I have the same problem with Googles’ Chrome sound issue or lack thereof.
It's strange but I recently added a HP Chromebook x360 (over priced) to my personal network that sync's my devices: Android Chrome OS and Google and Windows PC and Toshiba Laptop and a Samsung Tab 3 8in 2 smart phones and don't forget the smart TVs' and there connection to “Nest Mini” you got for free from ahhhhh oh Google. That's a lot of Sync-n going on.
My point is all these unnecessary things all connected into one Google account you can expect a little glitch now and then. They are still speaking different languages but getting better trying to make every device you may own work seamlessly together. Windows PC sync-ing with Android phones was unheard of. Maybe it's still is.
Many good choices in the mean time if you need sound?
My point is until Google, Android, Apple and Microsoft and on and on get it together (it's Googles bad on this.) Edge or Firefox or any one of the hundreds of search engine and browsers come to an agreement in their settings if I want to hear the sound.
Hi, just in case anyone has tried these options and still doesn't have any luck, maybe this will work.
Control Panel->Hardware and Sound->Sound->select properties for the device in question->Advanced tab->toggle Signal Enhancements/Enable audio enhancements
As of 2024 on Windows 10 I'm still having this issue, it happens to Spotify as well but I fix that by reinstalling it. This happens when I mess around with audio devices and have to set them up again (I.E rename them again in the sound control panel). My fix for this issue is as such:
Open settings (Win + I) > System > Sound > Advanced sound options > App volume and device preferences
If any are blank they will not work, make sure they all say the right audio device or "default". The reset button should set them all to default.
If none were blank then this probably wasn't your issue, keep scrolling. I hope this helps all the other Micahs out there (Micah is OP, made this account just to post my solution)
Chrome has no sound, though my system and other browsers work fine. I’ve tried restarts, resets, reinstalls, clearing data, incognito, disabling extensions, guest profile, and troubleshooting. Only Chrome Beta/Canary remain, but I’d prefer to avoid them if possible.
24 Комментариев
would a older version of chrome work in wn8.1?
из patrick mulreany
mine still isnt working at all. my chrome doesnt show up and none of the solutions worked
из Darren Tuttle
same with me
из markola64
@George Johnson I have the same problem with my JBL clip 3
из UndefinedDoggo
@George Johnson Same!!!
из UndefinedDoggo
Показать ещё 19 комментариев
