Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2690вопросов Показать все
Bottom half of the screen is unresponsive.
I replcaed my phone screen about a month ago using one of the guiides on this website. Everything worked fine. Then out of no where the bottom half of the screen stopped working and I cant use the keyboard or anything. Im not sure what to do.
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Выбранное решение
Well a super temporary fix is to use landscape mode. Where did you get the parts from? If it was here, ifixit has an AMAZING warranty program
Here's the email for support. That's usual the best bet
http://help.ifixit.com/article/136-email...
Though their phone support has recently gotten better
http://help.ifixit.com/article/135-conta...
After that, if you haven't purchased from ifixit, I would contact whomever you've purchased it from, and see if you can't get a replacement
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
This is the exact replacement screen i got....
https://www.amazon.com/gp/product/B01N2M...
Is there anything else I can do to fix it without having to replace the screen again?
из
Probably not. The touch not working on the bottom half is characteristic of a faulty screen. It would probably be easy to get a refund if you bought it on amazon.
из
It is now working. But I have to press a little hard to get it to respond. Could it be a partially disconnected wire or something???
из
Nah, it can't be the ic this time. Apple moved em
из
Try to reconnect the touch flex cable connector
из
my iPhone 6S bottom half isn’t working either. I cant even get into it because I need to do my password which  contains a 0 in it. when i press the 0 nothing appears to be working. what can I do?
Оценка 3
2 Комментариев:
The bottom half of my itel smartphone is not working. I don't know what to do
из
how did you fix it
из
Mine is not working too what I have to do
Оценка 1
Добавьте свой ответ
Jaredrett будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 40,836
