The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
25вопросов Показать все
After update my screen won't come back on.
Power light is on. I held down power button for 30 seconds and still nothing. Anything else I can do?
Это хороший вопрос?
Оценка 0
1 Комментарий
You may have to make a recovery drive with the recovery utility -- but before you resort to that, try connecting your TC2 to another display via HDMI. Then revert to the stable channel.
This is now a known issue -- a bug previously in the dev channel somehow made its way to the beta channel, it appears. It causes what you described on Toshiba Chromebook 2 "Swanky" devices.
из
Добавить комментарий
2 Ответов
Выбранное решение
This may help
https://support.google.com/chromebook/an...
Был ли этот ответ полезен?
Оценка 2
Do not do a recovery. Had same problem but hooked up to external monitor and saw a new update notification. Update fixes the issue. Must have been some bad code.
Оценка 0
Добавьте свой ответ
Vincent будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 170
