"Map Data is Unavailable"
I just installed all software on my new Garmin, maps are updated and enabled. When I try to plan a trip and enter an address I get the message "Map data is not available". I have tried everything but the GPS is not much good if I can't put an address into it!
Update (08/22/2017)
It will allow me to choose the destination on the map, so I think the map is good. But when choosing the address option, I get the message.
Это хороший вопрос?
Оценка 5
Добавить комментарий
Ответов (4)
Наиболее полезный ответ
Garmin Express software will automatically update software and download a map to the nuvi 2595. It can take hours, and if interrupted it may fail. My computer went to sleep while waiting for download, so I got the “map unavailable“ error message but also “You’re up to date “ message with the current software version. I changed computer sleep settings in Control Panel, then reloaded the map with Garmin Express. When completed you can see the map name and version under Settings/Map&Vehicle/myMaps with a green check mark. Under Settings/Device/About/Detailed maps you can see mapmaker and copyright info with recent date.
Был ли этот ответ полезен?
Оценка 1
Ensure the map is enabled on the device
To see which maps are loaded and ensure they are enabled:
Touch Tools
Touch Settings
Touch Map
Touch Info
Within this section you will be able to see all of the mapping loaded onto the device. If there is no checkmark next to the map(s) listed, touch the box to add a check. This will enable the mapping on the device.
Оценка 0
You can also take the help of Garmin Map Updater for updating the maps. This issue also sustained with me once. I contacted the customer service and the problem was sorted out.
Оценка 0
You can also take the help of '''free garmin map updates''' for updating the maps. I face same issue then I contacted the customer service and open the free garmin map update page the problem was sorted out.
Оценка 0
Добавьте свой ответ
Susan Smyers будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 7,306
