Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 with no image after screen replacement
I've been fixing iPhones for a while now with no problem. This time that I fixed it for a friend i replaced it with no problem it turned on and everything and about a week later the phone just went black but it is recognized when I connect it to iTunes. Could it be the logic board that was damaged? The phone has never been wet either.
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Выбранное решение
Have you checked the connector on the logic board? Check whether it is in good condition and clean it with Alcohol cleaning fluid to have a try.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I will try this thank you
из
After trying this multiple times it finally worked
из
Can you verify if it's no image or no backlight? Try shining a light on the screen and see if you can see anything. If so, it could be a problem with your backlight circuit.
Оценка 1
1 Комментарий:
There was light at first looked kind of purple but then just went out
из
This happend to me but on a different phone. The screen is broken talk with your seller
Оценка 0
1 Комментарий:
I thought it might be that too but i tried 3 different screens and one original that just had a crack
из
how you fixed your problem? please tell me, I have same problem
Оценка 0
Добавьте свой ответ
Alex будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 565
