Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Water damaged What to do now
This iphone 6 is waterdamaged. The screen does not work at all and when i put a new screen in it shows really faded images and doesnt respond to touch at all. Ive tried to put it in isopropyl alcohol but that did not seem to do anything. What do I do now.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Taking out the motherboard and removing the shields to soak in ISO (95% or greater) for a bit and gently scrubbing with a toothbrush is definitely helpful. However, you would want to decontaminate it by cleaning in an ultrasonic cleaner and rinsing well in the ISO.
Then, after letting it air dry for a few hours (to overnight) you would want to begin inspecting the board (preferably under a scope) to look for obvious signs of burnt (melted) under (Over)fill, signs of shorting (arching) on or near components...Probe with multimeter for shorts or possible component damage...
Sometimes, with water damaged phones, you can only hope to restore to do Data recovery due to the water getting under IC's and causing further damage down the road.
But taking to an experienced tech (Micro soldering) for inspection and diagnosing would be the best thing if you don't have an ultrasonic cleaner, microscope or micro soldering equipment or tools.
You have done more than most by simply cleaning with alcohol and not putting in a bag of rice! :) But still falling short of being able to properly decontaminate and clean the Logic board to begin the search for the damage.
If you are handy with this type of repair and have a few basic tools of the trade, you may get lucky and repair a blown filter, short, or even removing and replacing a faulty IC... but in my experience, even an experienced tech can fail to repair completely do to not being able to foresee future issues with corrosion under components that have no current issues.
Best of luck to you and I hope the repair goes good for you. If you can't find a local Micro Soldering repair shop, there are several here in the Ifixit Pros area that you could do a mail in service.
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
How would i remove the shields on the motherboard without a heatgun?
из
If you don't have a heat gun, or rework station, I'd recommend not taking off the shields...as you could inadvertently cause more damage trying to get them off...as there is solder surrounding each shield with pads connecting to board. Your best bet at this point would probably take it to or mail it to a Micro soldering repair shop. I know this doesn't help you much for a DIY inspection but even if you found an issue, it doesn't sound as if you'd be equipped to deal with it.
Some things are DIY, but what you have can be a challenge even for an experienced repair tech.
из
It always blows my mind when an OP doesn't upvote a well thought answer and then comes back for more info...at least you got mine.
из
TY @refectio ... I may not always have the best answer but try to help where I can. It can be frustrating trying to find an answer to a question as I well know! :) But to just have someone to bounce ideas from or get another perspective has helped me tremendously! almost 10 months into microsoldering and I learn so much from people like you who take the time out of their busy schedule to try and pay it forward. TY again, hope you have a great weekend!
из
Whatever @teetopp we're just glad you're here to help out. Thank you!
из
Добавьте свой ответ
Haris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 69
