Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4630вопросов Показать все
Problem with keyboard backlight only on a few keys
Hi!
I unfortunately had some liquid damage on my MBP 13" 2009 keyboard. So I went ahead and watched some Youtube Videos on how to take it apart and clean it.
The problem was, the backlight only worked on some keys in the center of the keyboard. I learned that the most common reason for this is improper alignment of the backlight. After hours and hours of trying to get it to work, I decided to trash the keyboard and get a replacement, since the keys were slightly worn out as well.
I ordered the same keyboard number, installed it, but still the same problem. Every keyboard component is new and I took extra care when installing it, but no luck.
I didnt find any threads on the internet where the problem still persisted after replacing the whole keyboard with the backlight.
I also tried resetting the SMC. Here is a picture of the problem:
http://imgur.com/HbWhWoF
Any help would be very appreciated!
Это хороший вопрос?
Оценка 2
1 Комментарий
Hey! Just experienced the same issue that you just had. I got that because of doing a custom colored macbook pro keyboard mod on my early 2011 13' macbook pro. I just finished troubleshooting after 2 hours and i came to the conclusion that it wasn't a broken keyboard backlight and it wasn't a LED Driver issue or board issue. It was the fact that the leds need to line up with those wholes of the acrylic plate.
из
Добавить комментарий
3 Ответов
Выбранное решение
Try a new original backlight; the backlights which come combined with keyboards are copy ones and not original. They do not use the same material to evenly distribute the light across the keyboard, so pretty much all of them either just light the middle, or are brighter in certain areas (especially Retina Pro models, where it will be very bright at the top and very dim at the bottom). The LEDs on the older models are in the middle of the backlight, which would explain why all the light is in the middle of your keyboard and not spreading.
Original new backlights will have white dots on the white material (compare to the original one), will have a RU sticker which peels off with the removable layer, and there will be blue tape for the adhesive around the side of the backlight, which will peel off in one piece, not multiple pieces like copies do. New originals are quite difficult to find for the older models, so it is usually best to get used original backlights, so you at least know it won't have this issue.
On the old non-Retina MacBooks, the keyboard backlight LEDs are either on or off; there is no "in between" where only some LEDs will light, unless the fault is with the keyboard backlight itself. The logic board just sends a voltage (KBDLED_ANODE) to 2 different pins of the backlight connector, which do the same thing. You can try plugging the backlight into the logic board loose to see if all the LEDs are lighting. On the newer Retina models, it is possible for some LEDs to not light, since they have 2 different cathode voltages, which cause the top row of LEDs to alternate on and off, but this is not possible on the older models unless it is a keyboard backlight issue, not logic board issue.
In short, you have been sent a non-original backlight where none of them work as well as the originals in my experience. Get an original new/used backlight and try this since the LED light originates from the middle of the keyboard, and the layers in the backlight cause it to be distributed evenly across the keyboard.
EDIT: what an original new backlight will look like https://www.aliexpress.com/item/Best-Qua...
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Hi and thanks for the reply!
I did exactly this and ordered a new backlight which looks similar to the one you linked to, it seems like much nicer build quality than the one that came with the keyboard.
I hooked it up before taking the whole Macbook apart again, but again the backlight is noticeably stronger in the middle section.
http://imgur.com/s5bZrpO
This is getting really really frustrating...
из
Definitely brand new with the RU label on the front adhesive cover? Some are sold without some of the stuff I mentioned (or adhesive covers are put back on wonky), if they are tested as faulty in the factory; 3rd parties then resell these as new.
I haven't seen this issue before, do all of the LEDs on the backlight light up fine? It's possible the LEDs are being sent a higher voltage than normal, which causes them to light up too bright (to a point where it is noticeably uneven), but again, I haven't seen this happen before, and it wouldn't happen without cause.
You can try laying it over the keyboard to see what it looks like, since it will light up a lot better than the previous one (and the brighter light in the middle may not be very noticeable when the keys and aluminium cut outs for the keys are covering it)
из
The backlight is not on the keyboard itself its a piece that you order separately on Aliexpress or ebay
Оценка 2
6 Комментариев:
Thanks for the reply!
I know that the backlight is a seperate part, I ordered a complete kit with all parts on eBay.
But sadly the problem still is present.
из
:( same thing with both?
из
Sadly yes... I dont know how this is possible, checked the alignment of the LEDs countless times
из
Then the LED driver logic on the main logic board needs to be investaged.
из
How can I accomplish this? I have a multimeter but no knowledge of LED driver logics :/
из
Показать 1 больше комментариев
Some of the corrosion after a spill is so hard to find it's almost impossible. We've had much better luck after getting an ultrasonic cleaner. We have been pulling boards out of machines we thought were toast (and had previously cleaned very well). I know these ultrasonic machines are expensive so you might contact a local repair place that has one and offer them $10-$20 to run it for you. I could save you the cost of a logic board. Transport the board in a static proof bag and keep your hubby fingers off of it ;-)
Оценка 1
Добавьте свой ответ
M3I будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 37
За всё время: 14,545
