7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220вопросов Показать все
After screen replacement, LCD acting very erratic.
There is some slight damage to the LCD in the top left corner.
Everything is moving and jumping on the LCD during start up and once I get to the home screen. I'm trying to see if I damaged the LCD during repair or if it's something I'm doing wrong. I tried turning the LCD on without screen being connected and same issue. I cleaned the flex cable on the LCD and same issue.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Thank you. I'm going to try to order a new LCD.
из
Добавить комментарий
1 ответ
Test LCD connections if that doesn't work I would say the LCD is defective or was damaged in the repair.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
The Wizard будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 40
