Why is the volume when playing from turntable very low
Volume is very low when using the Technics SL-1700 turntable
Это хороший вопрос?
Это хороший вопрос?
Hi!
Turntables will output high quality sound only if they are connected to a pre-amplifier. These devices are different from normal amplifiers in that they only take the raw sound from the turntable and make it louder. Having the turntable only connected to a standard amplifier will not be the same, the sound will be played back at a very low volume.
Был ли этот ответ полезен?
Make sure the turntable is connected into the phono input on the back and the dial is turned to phono on the front. Then there is a little button around the back (you might need a matchstick to press it as it’s countersunk from memory) which toggles the input between ‘normal’ and phono. You want it switched to phono. Good luck!
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,078
