PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Why is my r2 button not working
My r2 button wont work right I have to press it really hard in Battle feild wont work in gta5 .
Это хороший вопрос?
Счет 10
2 Комментариев
Chk the rubber on L buttons if ok!.
May need some control setting on call of duty. Shooting button response fast/slow
Hope this answer fix your prob.
из
I recently brought this PS4 controller on Amazon and now it’s not working on R2.
из
Добавить комментарий
4 Ответов
Выбранное решение
Dont know of this helps or not but…. If your controllers get dropped regularly, like mine do…..take it apart, carefully clean the contacts of the conductive film and it's respective contacts on the circuit board. I use 90%+ isopropyl alcohol and a few Q-tips. Scrub, but carefully. Then use a clean cloth to buff the film contacts and the board contacts. Make sure everything aligns correctly when you screw the circuit board back down. Screw the circuit board back down and connect the battery and try it out. Unless your controller is physically broken, or the rubber pads are torn or crushed, this should fix your problem. Unless it was submerged in fluids, just smashed to !&&*, or a button was physically broken from being to rough….this had fixed every single one I've come across with a “shoulder buttons worked and now they don't “ scenario. It's almost always that film. It moves and that was a design flaw.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Do you have any tips for the R2 activating when you're not pressing the trigger?
из
You could also switch the triggers to the bumpers (in the accessibility menu)if you dont want to break your controler or if you dont know how to work with the components (like me)
из
Наиболее полезный ответ
Could be a number of issues: the plunger on the inside of the button could be cracked, the button switch could be loose, or there could be dirt or damage to the button switch. Gonna have to open it up and have a look.
DualShock 4 (CUH-ZCT1U) Buttons Replacement
Счет 4
Here’s a simple solution to fix buttons that don’t seem to be working. It does requiring taking the controller apart.
https://www.youtube.com/watch?v=Lx3La8a1...
Счет 1
1 Комментарий:
Dude I logged in just to say thanks lol this link helped me big time. Just managed to fix my controller
из
How do i fix my r2 button to shoot without pulling it apart
Счет 0
3 Комментариев:
Blow air into it with ur mouth worked for me
из
Did not worked for me lol ear me out if there is another solution to repair it whitout pulling it apart
из
Coby Roberds that actually worked, thank you
из
Добавьте свой ответ
Lane Bauer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 22
За последние 7 дней: 208
За последние 30 дней: 784
За всё время: 160,261
