Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Dropped phone; turns on only when plugged in wall
I dropped my phone some time ago and unles it's plugged into a wall charger it won't come on. The phone has no cracks or anything so I suspect that there is some type of disconnect. I have tried troubleshooting by charging it all the way and then trying to turn it on after a little rest and I have done a factory reset as well. Neither of those things worked, unfortunately.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
@miraculyfe if it works on your wall charger but not while it is unplugged, check the battery. Make sure that all contacts are properly seated and ultimately you also want to try a new battery. It is a beast to do anything related to the battery on this phone as you can see with this guide
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Lakendria Bledsoe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,402
